2010 adaptive headlight adjustments
I recently had an issue with my passenger headlight. Water got in and was shorting it out internally. This was making the projectors flick side to side constantly.
I purchased a used headlamp unit and it has solved the flicking issue and it is working as excepted other then both beams appear to be low.
The in car adjustment is set to 0 hhighest position.
I have used the Allen bolt on the units to higher them but there wasn't a huge amount of adjustment left.
Can this be highered again within forscan calibration procedure?
