Mk4 niggles
Hi guys I've a few questions if anybody can help  ,my windows go down on the 1touch but don't go back up with 1 touch
Is there a way like I did with my mk3 to fold the mirrors in when I press the lock button I fitted a relay on my mk3 wondered if I could do the same  any help will be appreciated
You need to reset the one touch up, Handbook here
Don't know about the wing mirror. What year and spec is your MK4? Someone else may be able to help.
Thanks m8  I've a mk4 07 2.0 tdci titanium x
Thanks for the manual mate
  • 5 weeks later...
Reprogramming the one touch is easy, turn ignition on and wind the window all the way up and let go of the button. Then, hold the button in the wind window up position for about 5 seconds, let go and it should be done.
Folding mirrors  on lock are an easy mod, you need to replace the door module for one from a Mk4.5 and they will autoclose. However, if you then need to reprogram the one touch for any window you will need to swap back your old module in order to do it.
To get around that you would need to replace all 4 door modules from a Mk4.5. Not too expensive on eBay (that's where I got my 4 from).
