crank timing exceeded
hi all can anyone give advice on how to start my ford fiesta 1.6 tdci. crank timing exceeded come on after changing the crank sensor. how to get car started again ive done everything disconnected battery for 15mins but still no joy.
Use FORScan to see what the problem is.
Very likely it's the crank sensor.
  • Wrong sensor
  • Not fully connected.
  • Damaged wiring.
  • Out of timing position.
  • Wrong sensor
  • Damaged wiring.
how do you set timing positon
  • Wrong sensor
  • Damaged wiring.
Tried old sensor back in still won't start it is turning over but won't fire up
What are the DTC's read by using FORScan ?
WILL CHECK TOMOROW
21 hours ago, M200HUT said:
WILL CHECK TOMOROW
WILL CHECK TOMOROW
No fault code showing
  • 10 months later...
I got similar problem with cranking time exceeded can't reset it
