Dash Lights
I had issues, mentioned elsewhere on forum, regarding battery drain, which I think was cured by disconnecting the Blue Tooth Module.
But now driving it in the dark more I have noticed that when the ignition is turned off some of the warning lights stay on, very dimly for quite a while before going out completely.
I suspect an earthing issue, does anyone know if there is a common earth  or could it be normal ?
My thoughts would be a failing/faulty instrument cluster.
What warning lights are staying on ?
Oil, Ignition, Seatbelt and the 'A' for stop-start. All very dim.
Is the failing cluster a known issue or my bad luck ?
Could be water ingress to the GEM.
@rd457 would know more about a Mondeo 2000 instrument cluster.
I've never encountered a Mk2/3 Mondeo cluster, sorry. I have however worked on Transit units of similar vintage. If it has a 32-pin connector the connector solder joints could be cracked, but very unlikely if 26-pin. I've also had some success with scrubbing the circuit boards clean with IPA. Maybe that's all yours needs.
Doh ! Sorry I didn't specify the car. It is for a 2015 KA which was my Wife's. I'm running til sold.
My car is the Mondeo, which has issues but the cluster is fine, sort of ! 😉
Oh, well a 2015 KA shouldn't be affected by cracked solder joints, and probably too new to need a clean.
9 hours ago, Theshed said:
It is for a 2015 KA
It's a common issue on the KA. Don't know what causes it but there have quite a few people with the same or similar issue on the forum.
Thanks for the input. Does not appear to be an issue, but I wonder was this contributing to the battery going flat.
The Auto-Elec who looked at that problem did mention a draw from the BCM. Putting 2+2 together ? 🤔
