fiesta 1.25 2014 help please BCM dn1t-15k600-JG
HI all
i think i have a problem with the bcm fiesta 2014
central locking playing up ,electric windows,electric mirrors,also windscreen washer all intermittent work then they stop working ------ I'm thinking the bcm is faulty
what i wanted to ask is,i have found many online but my numbers are - dn1t-15k600-JG----- but,i cant find a JG the last part (JG)  i have found -JD---or ---GF
i cant seem to find a JG...anyone know if this part has to be exact, as all the other numbers are the same apart from the last 2 letters. many thanks.
The JD might work, but is an older version of yours.
The GF probably won't work.
Generally the very last letter can be different as long as it is higher up the alphabet.
You may need to update the firmware to your current level, if it's cheap try it
hi sorry only just seen the replies, so if i copy firmware from mine and put it on a older one i might be ok. forscan can do this right ?
Why not use this one ?
https://www.ebay.co.uk/p/7022816371
wow thank you i didn't see that.??
