Anyone know what normal is?
1.6 diesel SOHC 8v tzja idle reads.
The Differential Pressure of zero looks very suspicious for a 15 year old car and if you change the MAF units to metric ones than that will make more sense.
Need to go for a drive in a min so will get back with updates.
Idle and 3k ish table
The MAP, MAF and Differential Pressure look ok although to get meaningful data the car needs to be driven not just revved stationary.
If you had said what your concern is then someone may be able to offer some more advice.
Vibrates more than id like. No injector feedback from the ecm but doing a leak off test tomorrow once i recieve a new pipe coz bound to break the ***** green clip things.
Mechanic said hydro mount but was doing it before and after I got a new one so im after a diagnosis as to a mechanical part.
Not always present so not suspecting flywheel.
Other people say worn injector. Only other guess is clogging egr cooler or inlet.
