ABS fault C1095 pump motor circuit failure, low voltage
Hi all,
For the past couple of weeks the ABS light has been staying illuminated on the dash. I've scanned with FORscan and it's reporting fault code C1095 (pump motor circuit failure, low voltage to the module) . I clear the fault but each time a few yards down the road it comes back again. I replaced the ABS unit (4S61-2M110-DA) almost exactly two years ago to the day after the old one also reported C1095 pump motor circuit failure so same fault code but different description. I've just replaced the battery so not that but don't have a pin-out of the ABS connector to check the voltage there.
Could someone please provide a pin-out for the ABS connector (it's a Fiesta Mk6.5 1.25i which I think uses an ATE MK60 module).
Any suggestions of what to check before replacing the module again.
Thanks,
Jon
