Suitable route for a amplifier power wire run.
Would any of you know a decent position/place to run a 4 gauge power wire through the front bulkhead from the batt to the interior cabin please.
I have checked online and most the chavs run it into a plastic gromit on the exterior on the A pillar not only do that look stupid but also it's a recipe for moisture. Running power wires was a lot easier in 90s/2000s 🙄
Much appreciated it's a 1.5 tdci if that makes a difference
I have a 2009 fiesta and ran mine through the big grommet behind the battery..used a steel wire to push through from inside to outside...attached the cable by taping around the wire and sprayed with wd40..very tight but that's a good thing 😎
Thank you mate I literally just did the same thing but all I had was a fencing sword 😅...
Tight is always good ... 😁
