IPMA U2100
Hello, I updated my IPMA since I wasn't able to enable WWA (even tho the hardware itself supports it, it reported "Writing failed incompatible configuration".)
Updated via J2534 interface and went well.
IPMA - Image Processing Module A
Part number: H1BT-19H406-BG
Calibration level: N1BT-19H406-BA
Strategy : JX7T-14F397-AH
Calibration: H1BT-14F398-AG
Last version before update was H1BT-19H406-BG
Right now it reports DTC U2100-AF Initial Calibration Not Complete
I tried to:
-do calibration camera (in this order: load factory ab - calibrate - reboot module)
-do calibration camera (in this order: load saved ab - calibrate - reboot module)
-upload as built saved before
-upload as built from ford servers
All of this and still reports the DTC!
I will appricciate any help. Thanks!
  • 1 month later...
Did you get this fixed I have replaced my camera and get the same errors U2100. I'm unable to calibrate it with this code in place. I've now tried 2 seconds hand cameras and both do the same.
I'd roll the software back to original
What software? Roll back to what?
Firmware then! Strategy/calibration
Back to what it was before you updated it
Oh I've since bought another one L1TT version and that's the same. Can't calibrate, original MK8 Fiesta firmware on it.
 Forscan dev says it's not ForScan but 2 faulty cameras?? I don't think so.
I tried to:
I managed to sort my U2100 out, its due to incompatible hardware, ive now installed mine and even got wrong way warning and pre collision detection working.
Double check the part number matches the part required for you vehicle looking at your post it looks like your camera is from a Ford Ranger but flashed it with Fiesta firmware, this doesn't work you will need a new camera, model number : H1BT-19H406-CE
