  1. Tap the 3-dot menu (â‹®) in the top-right corner of the browser.
Sony stereo speaker wire colours
I tried to install a line out converter today, and all the online guides seem to use the basic head unit and not the Sony one... popped out the stereo to be greeted with totally different harness with different colour coding ...
Could somebody point me in the right direction 🤔 to a wiring diagram of the correct connector please.
And I only had a hour to do the job I had to reassemble the car.. before light fails.
Added some photos of what I seen and the radio
All wired in and working so if anyone if using same line out converter with same sony system.
Left front speaker is white + white/brown -
Right front speaker is white/violet + white/orange -
Fuse tapped into fuse postion 1 igniton for line output converter live.. make sure you use bottom pin of fuse1 on fuse tap as thats live and correct so fuse point towards drivers side and not towards passanger door.
For the line outpet converter ground, i used a ground bolt thats just under the glove box passenger kick panel, unbolt slide in your ground terminal tighten.
Everything else is standard amp wiring.
I will suppy pictures if anyone wants them.
