Aircon Pulley help.
I get quite intense pulley noise when the A/C is engaged from the Drivers side of the engine bay, stops as soon as you turn the A/C off.
Can anyone help me narrow down which pulley might be the offender so I can figure out if I want to tackle it myself or not? A/C works fine.
Thankyou
No.  You need to remove the belt(s) and check each pulley by hand.  We can't diagnose it over the internet.
What !!!
Not even if the OP has an App for that ? 🤣
1 hour ago, unofix said:
What !!!
Nar then! He could film it & upload it to youtube!! That's common these days....
I was hoping there would be one that was common, Nevermind 🙄
You could just run your car, with the air con engaged and have a listen under the bonnet...
Wow. Bunch of toddlers here eh.
or maybe Tossers is more appropriate
Good luck getting help in the future with that approach. 🙄
Is it like a  quick belt whistle when the A/C compressor engages ? Mine is doing this for a while...A/C is working fine, might just need the the belt and the pulleys replaced.
