O2 Sensor issue?
1.25 2012 Fiesta
Engine light is on and with a scanner I get the P0420 error code
On looking at the sensor data I get the following (as a snap shot at idle) but this is when the car is up to temperature after a longish journey:
Oxygen sensor 1 Bank 1 Voltage - 0.74v
Oxygen sensor 1 Bank 1 Short term fuel trim - 0.78%
Oxygen sensor 2 Bank 1 Voltage - 0.78v
Oxygen sensor 2 Bank 1 Short term fuel trim - n/a%
The values vary a little, but the Oxygen sensor 2 Bank 1 Short term fuel trim value always says n/a
Does this mean the sensor is not working and needs replacing.....?
I have re-set the warning light a few times and it stays off for quite a while before coming back on again
Just curious to see if this is a simple change of the sensor or if its the cat itself - and if its the cat, will cleaning it work?
