indicator problem, 2020 Fiesta ST-line EcoBoost
Hi
Have a bazar indicator problem,  just taken car for MOT and it failed due to lefthand repeater in mirror flashing when righthand direction selected!  and then the left repeater not working when left direction selected...
 The right side all work fine and all indicators work when hazards are selected...  Is it possible to configure a door module to the wrong side? or is this a BCM config issue?  I have an Autel scanner but can't see anything obvious.
Any help appreciated, 🙂
Put it away in the kitchen draw and then get yourself set up with FORScan so you can read all of the Ford specific DTC's.
FORScan:
On 4/7/2024 at 8:59 PM, unofix said:
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
OR
For diagnostic use only:
