Where can I find the calibration file and As-built ABS?
My car has a code U3000:48
VIN MNB8MNB8XXARJ8EY24098
IlYou can Help?
Welcome!
U codes are communication errors.
I suggest you search on ford U3000:48 and look at the multiple sites describing the problem.
To me it looks like an ABS module issue requiring a basic check on powers, grounds and CAN integrity before perhaps getting the module repaired as in:
https://www.actronics.co.uk/news/solution-for-ford-error-code-u3000-control-module
OR
https://www.ecutesting.com/product-catalogue/ford/fiesta/abs-pump-ecumodule-combined/
Depending on your location?
Also consider Forscan and lead if you aren't using (not much history or detail which always helps)?
If you mean you have fixed the fault and do need a specific file, ignore the above and sorry, I can't help.
INVALID VIN.
