Handbrake on Mk 7 2015
Hi my daughters 2015 fiesta handbrake has no tension until the lever is half way up ? Is this correct should I be looking at cable adjustment on handbrake or adjusters on drums ? Any guides on how to do this thanks
3 to 4 clicks is normal. Any more than that and it needs the rear brakes serviced. Assuming it has rear drum brakes then check that the cylinder is not leaking and that the brake shoes are in good condition. Make sure the auto adjusters are free to move and are correctly set.
How do you correctly set the rear adjusters?
First problem the head on the screw holding drum is damaged do I need the 2 screws holding it on or can I drill one out . Any ideas to get it out ?
