Restrains control module not functioning
I wanted to retrofit an auto dimming rearview mirror so I bought an A-pillar harness that fitted the specs of my fiesta, after the install my microphone didn’t work and the IPMA was throwing codes, later I also noticed that my RCM not working correctly cause the DDM and PDM were not seeing the RCM and I noticed that the amber passenger airbag symbol turned off on my dashboard and came on in the IPC.
I switched back to the original harness cause I didn’t know what was going on and the IPMA and microphone are working again except for the RCM, I tried resetting the crash data, rebooting it, checked the continuity between the the A-pillar connectors and the loom side and I can’t figure out what the problem is.
I also don’t get how the A-pillar harness can cause a problem with the airbags cause it’s not physically connected to the airbags, only to the IPMA, Rain sensor, heating element for the IPMA, dome lights and the microphone.
any help is greatly appreciated :)
Have you checked the connections to the side airbags ?
How are those connected? I’m not familiar with the way they’re connected.
