Tdci Injector Knock
The guy who fixed my turbo the other day noted that one of the injectors was a bit "noisy". I already knew about this (though I don't know which injector it is) but I figured if it ain't broke, don't touch it. I don't have any running problems or DTCs pertaining to injector knock threshold.
I'm well aware that the injectors and flywheel are the big two things that my car still has to suffer with, so at what point should I address the injector issue? What happens if I don't?
Do quick leak off an also use stethoscope or screwdriver stick it to top of each injector an put ur ear to the other end an see which is noisiest an see if that one shows up on leak off test
