Rumble And Hummimg
hi im new to all this so bear with me , i have a 2005 1.6 lx focus 66.000 miles , at about 55 plus i get a wining from seems rear of car , i jacked it up and no play in wheels but o/s seems noisier , when normal driving 30-40 just seems bit noise than usual . hope you can get my jist , thanks rear of car not front
Might be a rear wheel bearing ?
think i may get two hub bearings and try em
Wheel bearing i had the same no play but when it was changed it was close to collapsing garage did mine as the hub rusts to the backing plate and isnt easy to get off also the rear abs sensor is there £126 for bearing labour and tracking fords a lot dearer
yep drove it today and 99.9% say its a bearing , o/s seems noisey but think do em both , and it is def the back ones
