Clutch Kits
hi there ive got to change the clutch and ive been told i might have to do the flywheel aswell cant believe how much its going to cost been qouted £760 is there any one you can do it alot cheaper for me in the bristol area please help ;)
What car is this on?
you'll only need to do the flywheel if you have a Tdci version. This is fitted with a dual-mass flywheel, which it is best to change with the clutch. You're not going to find anybody to do it for under £600 unless you're very lucky.
I'm guessing it was "You might as well do it whilst you have the gearbox off". It saves removing the gearbox and clutch again later if it needs doing so extra labour costs.
Sent from my HUAWEI Ascend P2 using Ford OC mobile app
need to know which car it is. on a single mass flywheel you can just clean the surface up and it'll be fine for another 500,000 miles
I'm guessing an Escort as profile shows and the teeth can wear out much earlier than 500k lol especially with short journeys.
But it's in the focus section so who knows
Definitely.
Try getting a quote from mr clutch, they gave me a quote on my focus for just a clutch £250
Sent from my automated robot M1X-M4573R-700N3Y
sorry every one ive just updated my profile its a focus 2001 1.8 tddi im not sure if its a dual mass flywheel or single one aswell please help
it was mr clutch that qouted me 760 for clutch and flywheel
Don't go paying 760 getting well ripped Indy garage should do the job for around 250/350 I,d of done for yer for less than that if you were down this way .
That seems very high. Did you do it online mate?
Looking at the Haynes manual, it looks like a single mass flywheel for the 2001 TDDI. It doesn't look like anything special. Don't quote me on that, though.
2001 tddi does not have a dmf. It will be more expensive than the petrol version as it is fitted with the mondeo box. Should cost less than£350
