Drl
Back last October I had DRLs fitted and as you know they come on when the car is started but I was wondering how I wire them up so they come on with the side lights when I open the car??
Luke
It will be pretty easy, I presume they will be going to the ignition fuse at the moment so all you would have to do Is take the positives and connect it in to the sidelight cable, probably best using a splice connector.
Well I'm not very good at things like that but does it still mean they will come on with the ignition and turn off when it run the lights on and things
Where are these wires found. Sorry if I'm asking awkward questions!!!
No, it means they will only be on with the side lights and go off with them too
