A/c Auto On
Does anyone know of a way I can stop the Air Conditioning kicking into life when I put the heaters on in my car?
I think the A/c is in need of some attention as when it turns on you can hear a very loud noise that sounds like dodgy bearings (Does the Air Con system have any bearings?)
I thought about removing a fuse, but when I looked at the fuses there are quite a few that relate to the A/C/heating System.
Cheers
Gary
Make sure the blowers are not pointing at the windscreen, this enables the A/C automatically.
That makes sense. I always point them at the windscreen when I turn the car off so I dont get a freezing blast of cold air to the face when I start it up.
Sent from my GT-I9505 using Ford OC mobile app
The noise is probably just the standard noise from the A/C compressor. They aren't the quietest devices on the planet.
Make sure to run the A/C at least once every couple of weeks, even in winter. The a/c coolant contains lubricant and if you don't run it for a period of time, the seals will dry out and the a/c system will leak. Just watch this forum when the first hot weather arrives - I guarantee at least a couple of posts a week asking why the A/C is no longer working. This is why.
Is there a noticable difference with the Ford A/c units compared to other manufacturers?
I had a Vauxhall prior to this and you couldn't really hear it.
I'll make sure I run it every now and again to keep it happy.
Cheers
It was probably broken. :P
(sorry, couldn't help myself) :lol:
Hahahahaha. Probably was mate.....there is a reason I didn't buy another Vauxhall and went for a focus
