The Little Ecoboost...
Just some prism 501 LED bulbs from Halfrauds... I didn't mind getting them from there cause 1) i couldn't be bothered to wait for delivery and 2) dad gets discount with his trade card... But TBH, even the ones off eBay are just as good.
  • Replies 99
  • Views 16k
  • So since last, all's been fitted including the surprise but I dunno how to tell you guys the surprise yet as there a few minor touches anyway before it is revealed. So first, the induction pipes, so m
  • Stop wasting money on paint and get your grill sorted pronto ;)
  • Nathan54771
    Nathan54771
    Yehh it looks similar to the j1, I've got a k&n panel filter for now :)
the front lights are looking much better after the de tangoing.
as said such a small mod but worth it as it makes a diffrence
Could you link me to the bulbs you used for your de tango? Thanks!
Edit:
Think I found them, Philips Silver Vision PY21W
Right? :-)
Sent from my Nexus 5 using Ford OC mobile app
I just got some generic ones from ace parts, £7.50 delivered for all 4, seems to do the trick just fine. And they are bright enough. Can't get link as their site doesn't work properly in my phone so apologies there mate.
Edit: those bulbs would work though, PY21W is the bulb code
So after spending the weekend away, finally de-tango'd rear lights (pictures to follow shortly) and let my cousin loose on the car with his cleaning products and the results:
A Little Iron.X
A little Snow Foam
And then the final result:
10170827_244824475704497_110338974657297
looking nice and clean.
cant beat a nice clean crisp looking car
Opinions guys, I've found all my previous equipment for a sub in boot from my old Corsa C (don't hate it was a cheap 1st car). But I'm not sure if i should?
So as promised... Pictures of Rear De-Tango'ing
Before:
After:
New toy arrived today... Won't be fitted til tomorrow evening at the earliest... but probably not actually til wednesday... Can anyone guess what it is?
Team heko wind deflectors.
Mark
So in the box were some wind deflectors as @sparksy32 guessed correctly:
Got round to installing them... very simple, less than 5 minutes. Take a look see at some before after shots:
Before:
After:
So collected my reserved mist washer jets (non-heated) from ford and the old ones were out and the new ones went in:
Before:
After:
Hi divszy, cars looking great...wish it was that easy to detango the front lights on my focus, think it makes it look so much better
How much did you pay for the washer jets from ford? Debating getting some mist type ones also
might not be so easy to de-tango but well worth it... as for the mist jets, the non heated ones, which i got, were only £7.32
That's not as expensive as I expected from ford tbh
Ford continue to surprise me!
Only thing I would say is to ring up your local ford parts before hand and make sure they have it in stock. Rang multiple dealers around me and only one had them in stock ready.
  • 4 weeks later...
So it's been a while since I've updated and too be truthfully honest, not a lot has happened since. Since the last update, the side indicator bulbs have come:
They haven't been fitted yet but here is a before shot anyway:
This arrived:
Which then allowed me to do this:
From this:
You may have noticed that the metal battery cover has been painted from black to red to match the on going colour scheme.
I also went out for a couple of late night drives with a friend and he managed to get these shots taken:
And lastly, went out for a little spin with nick around loughborough and managed to get some good snaps but these snaps are too follow shortly once I've managed to go through and sort them. So yeah, so since last, it's only really been bonnet struts that has been fitted. C&C's welcome. But as always, more to come.
Bonnet strut looks good mate - nice and sturdy... Are you happy with the quality of it - Does it hold the bonnet well? Where did you get it from? - Link please!
I'm happy with it certainly. Was well worth the money. Holds the bonnet very easily, the bonnets quite light so you only need the one. Got it off NBstyling on Facebook. But sico developments do the same kit on their site.
I'm in the process of fitting mine and I've run into a problem. The idiots that out everything together have painted the back bolt and it's solid, anyone ideas on removing it? Few attempts already abd it's just striping it!
Cheers
Marc
Sent from my LG-D802 using Ford OC mobile app
Put some wd40 on the bolt give it 5mins to soak get a socket head and hammer it gently onto the bolt head then get a socket and put a bar across the handle and gently pull should stop it stripping if not drill it out and new bolt it
Is that for the ground? If it is, you wanna take off the bolt through the front, as the back is welded on. And if it gets stuck, prise it as you undo with a flat screwdriver
Cheers mate, wd40 already on it :)
Marc
Mate it's stuck solid from the front my spanner just slips, any tips?
Marc
Looking good, Divszy. How do you like the hose and AS induction kit? Does it do anything other than make a lot of noise?
