Glove Box
Hi guys my bluetooth doesn't work on my 58 plate focus ST so iv tea I need to try and reset to module which is behind the glove box. Was just wondering how do you remove the glove box?
There's a handful of little torx screws holding it in place, 7 all in I think, but can't remember exactly where. There are 4 obvious ones, then three more along the bottom behind little plastic flaps. You should be able to find them easy enough when you go to look. The box will come loose then.
You'll need to disconnect any plugs you have there, like an AUX input for example, and the box will just slide fully out then.
Also, if you have the 'air conditioned' glovebox, on the right hand side there will be a little vent which twists to open/close. Try get your hand in to the side (on outside of box) to pry this off before pulling too hard on it to save breaking the little plastic clips which hold it in place.
Ok thanks iv got the air con glove box il have a look this weekend
No worries mate, should be straightforward enough when you get a closer look. Good luck with it!
Cheers mate :)
