Focus 1,6Tdci Titanum Facelift - Only 3,5V On Abs Sensor Contact Rear Right - Should Be 10,5V
The abs lamp is on, but not all the time .
How likely is the ABS pump ( module ) the problem?
Is it common that a failure on the ABS module starts intermittent ?
My garage says they must do an extensive search to check resistance between ABS sensor contact and ABS module .
Where can i find the ABS module, ( I'd love a picture :-) I guess there can be a faulty contact ?
What irritates me is that if I could find it and open it , there is a chance that I could do an easy
solder to fix it . I know that this module is expensive.
I have not found any common issue regarding this fault....
The BCM (brake control module) is integrated into the ABS (or ESP) pump. This pump is located on the left side of the engine bay behind the battery.
