Mk 7.5 Zetec S Headlamp Swap
Hope this isn't an old question but does any one know if the headlamps on the 13/14 titanium fiestas with led drl's will fit / plug n play in my H15 non-led 13/14 zetec s? its more of a loom thing, ie are they the same? then there's the cost. many thank if you can help :rolleyes:
I believe it was mentioned before that the headlights need programming by ford? Because the LEDs dim when you have the headlights on. And it is apparently a pain to do so!
Sent from my GT-I9505 using Ford OC mobile app
The loom plugs are also different I believe. Due to different bulbs Etc. So for £400 a pair it's a risky retrofit. Not to mention the cost of reprogramming if it's needed.
I wish it was plug and play :(
Many thanks for the replies, bit of a bummer... I thought i'd found a solution on ebay 111247417336 but they're not zetec style. Maybe i'll go for a pair of blue tint H15 from ebay 121241290945 but at £47 from italy that seems expensive. I'll keep looking.
Someone on here's tried to bulbs matey and apparently wasn't worth the money so got returned. We're all waiting on a good upgrade too :(
