Catalytic Convertor Facelift Fit Mk2?
My catalytic convertor has just failed on my 1.6 petrol 2006
Would a catalytic convertor from a 1.6 petrol 2008 facelift fit?
the code on the 2008 model is 7m515f297ea t2a1a
Hi
When you say failed
do you mean fallen apart
failed the emissions test ?
Jamie
ive got a code p0420 code on my dash
its been cleared but contunes to come on.
Hi Mark, Could I get Reg numbers off both vehicles please. Early 2008 might fit but would rather double check things like Hatch/Estate/Saloon etc.
Cheers Chris.
hi sent through the reg numbers on PM thanks
garage mentioned it might be worth getting full service done ie spark plug change etc and see if the light comes back on after that ????
I wouldn't jump to the conclusion of the cat has failed until it is absolutely definite. A fault code does not necessarily tell you what is at fault, it tells you what is out of parameter.
original cats tend to be quite robust too.
