Immobiliser Code 13
like the title says I have a code 13 on my immobiliser, does anyone know how I sort this properly without bypassing the immobiliser?
many thank.
What is ur car
fiesta 35 van, 2001 mk4 or 5 i'm not quite sure.
many thanks.
Non-PATS key or damaged encoded ignition key, or no key code received.
have already tried swapping the immobiliser ring with no luck😬! what would the next step be to sort it out properly? I read that the ecu can be swapped with the corresponding key used? or can an auto tech sort this out?
many thanks.
Did u try spare key or programming key again
all I have is one black key?
many thanks.
Has it got a blue or red chip in it u would first have try reprogram key or get new key that first step
it has a red cover on the chip? who would I go to for reprogramming?
many thanks.
Ford or maybe a specialist could do it google it an ring round try get best price
cheers, will give it a go, however is there a way of doing it by changing the ecu over?
many thanks.
You could but u have change ignition barrel to suit key a lot more hassle buyin ecu an barrel den fitting them be easier bite bullet an buy new key an try get both them programmed together cause there is a chance ur key is broke an wont program so new key best way go
