Fog Lights
since i had my bumper taken off and sprayed, my fog lights are steamed up inside, is there a fix for this, what is likely to of failed.
Seals broken on the lights, Air getting inside, heating up and cooling down etc.
is it a case of new lights then, or can they be fixed
Sealant or replace up to you.
Sent from my HTC One_M8 using Ford OC mobile app
Are you sure you have the bulbs inserted correctly and tight. That maybe the prob if it's only just started with the bumper. Unless the reason for the bumper was you had damage from an accident
