Thud Noise From Front Drivers Side
Hi all need help with a thud noise on the drivers side front, you can also feel it on that side, do you have any idea what it could be or if you have had the same problem, changed the lower arm and that did nothing its still there
just to add its not a metal on metal sound more of a thudding sound but only from that side
cheers in advance
lee
Is it not your ABS testing itself? Mine does the same thing, but only one thud just after I set off
no its when going over bumps
It's your suspension. 2 possible causes jump out at me - a worn bushing of the anti-roll bar, or a sheared spring.
