Is There Any Way To Clear Codes Stored On Pcm?
Have both elm327 and vcm cables + ELMconfig & Focom.
The code that re appears is P1260, which I think has lead the pcm to disable engine from starting.
Have you tried ForScan?
Nope?
My friend thinks it's been an issue when pairing new cluster to pcm even though it finished successfully.
So getting ids set up now.
Dont know of this of any use but when i had my cluster changed at dealer they had to recode the whole immo circuits and recode the keys. Might be related somehow or something that may need doing?
Yes reprogrammed keys (2) first mate
Just about to hit it with ids
IDS done the job, all works fine now. Chuffed!
Was going to say if the code was PAT's or security related it'd take more than a standard DTC type code clearing tool to do the honours. Least you've got it fixed now :)
Yes it did buddy, luckily I had the daddy of software to attack it with lol :)
Really pleased as pre facelift and facelift cluster is like night and day!
