1.8 Diesel Fuse Box Part Numbers
Had been having issues with my focus killing the battery overnight. Took it to a garage they couldn't figure it out so found a mobile mechanic who specialises in electrical systems. He narrowed the fault to the fuse board and suggested I find a part second hand as new they are just a wee bit expensive.
The fuse board fitted has a part number of 7m5t-14a073-CC
The first question is can I fit a fuse board which has the same part number with exception to the last number?
The second question is does it then need reprogrammed? Or will it be fine as a straight swap?
Third question is if I find one the same part number will that need any programming or just a straight swap?
Many thanks, hope someone knows more than I do!
Last number should read letter... Ie instead of CC, it would end CB
CC board-
http://pages.ebay.com/link/?nav=item.view&id=261910810742&alt=web
CB board-
http://pages.ebay.com/link/?nav=item.view&id=400929107910&alt=web
I believe that as long as you get a board with the same or higher end letters you'll have no problems with functionality.
I believe it may need programming onto the car, I'm sure someone can confirm this?
