Please Help A New Streetka Owner
Hello there. My new streetkas coolant level rises when warm above the max marking and when left for about 4/5 hours on my drive it drops in between the max and min markings. Also can hear a gurgling sounds from some of the hoses which could be trapped air?
Theres no sludge in the tank or on the oil cap and in the dip stick
No leeks i can see and no water or oil on my drive.
Only thing to say is when i got the car home the power steering reservoir cap was loose and the fluid was jumping about a bit not boiling. so could be air from the cap loose? Please could really do with your help on this one.
Matthew
Sounds like you answerd your own question. It's most probably air in the system that needs bleeding out. As for the power steering fluid that may well need topping up and check all caps are tight inc the brake res
  • 3 weeks later...
Agree with the cap. I would look to replace the cap as might not be sealing properly and may be drawing air back in.
did you get it sorted ??
