Please Help 2.0 Tdci 100kw
hello! please help to name that part , i have oil leek on it, and probably that why car have power loose and engine lamp on . thanks !
post-67005-0-59717800-1436437205_thumb.j
mass air flow sensor common fault on Peugeot engines
if the EML is on get the codes read to point you in the direction of what is wrong, as for the oil leak where is it leaking from?
On this double tube is two like sensors ,one on left side other same on right side but turned to bottom and there is connected vacuum pipe so from this "sensor" is leeking oil. Shuoud be this problem couse I changed MAF but didn't fix that leak and in one month that MAF become dusty.
Throttle flap .need replace cant find any in UK part n.9657522680 50cddf4
