Dash Cam
I found out that whilst it does reduce insurance a bit, it also bumps it up a bit because its adding to the value of the car an potentially increases break in risk.
Net result is no difference at all. Until some bottom-hole hits you!
edit. apparently the A word is a no no! lol
Edited by Dee_82
Bypassing swear filter.
Hopefully it's as simple as that :) a clock not set won't show the right time, so hopefully once you correct it things will behave as expected
Sent from my GT-I9195 using Tapatalk
it was set but come up saying battery low .
Not sure telling insurance is a good idea...useful if its not your fault, but what if you record proof of you being at fault! :lol:
Yeah if the time is set and it loses all battery power including reserve then it will go back to default settings, but they are meant to shut off leaving minimal power to keep the settings maintained. If it's not doing this speak to your retailer
Not sure telling insurance is a good idea...useful if its not your fault, but what if you record proof of you being at fault! [emoji38]
Then when they ask, it seems the memory card was full and didn't save the incident... Lol
Haha, can't argue with that. :lol:
Just to let you know that a number of our insurance schemes give discounts for a wide range of in-car cameras.
Regards,
Dan.
I have fitted dash cam's to most of the families car's now gives my 70yr old man piece of mind and me and when some guy cut her up and started on her she pointed to the camera and give him some chosen words he got back in his car and drove off I see his car around let's see if he acts like that with me lol
Sent from my iPod touch using Ford OC
http://www.ebay.co.uk/ulk/itm/221813954816
I use these with a piggy back fuse then tuck all wiring away if you use the right fuse it powers up when ignition is turned on fuse 100/110 and 135 for a focus
Lol, someone cut me up badly on a roundabout last week (saw me already on the roundabout but pulled out anyway!), I should've ignored it but was already having a bad day and blasted the horn at him. He slammed on the brakes an started swearing and gesturing in his mirror...I just pointed to the camera and he shot off. :lol:
