2005 1.4 Tdci Injector Seals
Hi guys / gals
1 of my injectors is leaking so I've decided to replace the seal but I'm a bit unsure whether I need to replace the high pressure fuel pipe as directed by Mr Haynes, if I do then should I be replacing all 4 injector seals or just the 1 that's leaking.
Thoughts appreciated.
Last time I did a 1.4 I replaced all four seals. I re-used the feed pipes and it was fine, just make sure everything is scrupulously clean.
Thanks for the advice.
