USB bad media
Hi all,
I have a ford fiesta ecboost 2014 plate. I can steam all my music, my phone connects fine and everything all connects up great to the usb slot except my one usb stick.
I have a USB stick with tons of songs that i use on my PC with no issues at all, but when i plug it into the cars usb, i just get a messege saying" bad media device" or something along those lines.
Ive checked the usb on my pc and its fine, all songs play no issues. Any idea on how i can resolve this?
Regards,
What filesystem is it?
Sync can't read NTFS, needs to be FAT32.
exFAT might work (it does on Sync 2), not sure about Sync 1.
Might just be the format of the songs,  try putting some on there in a different format and see if it will read them?
Just checked it is FAT32. sony usb.
It used to work just fine up until about a month ago!
Just removed about 100 songs form it, cleared the space, reformatted the USB stick and then downloaded all the songs again, but no luck so far :( wont play anything off this USB
Have you tried a different usb with just a handful of mp3s on to test if it is a problem with the car?
Just read your post and used my little sisters usb and all of her songs are playing fine. So i can now only assume its an issue with my usb. But reformatted, the songs are fine, running the right filesystem, what else could it be?
I'd trying running an error check on your USB. Maybe it has developed a fault and Sync is more sensitive to it than your PC?
Did you try your songs on her USB? I know its a long shot but 1 file/song or a few of them could mean Sync isn't reading the full thing? If you have formatted the USB stick (whilst changing the format to FAT32) then I would say to just try a new USB stick (Few quid on Amazon) and just get a reputable one like SanDisk.
You could try formatting it, and trying 1 song, ensuring its MP3, FAT32 etc and see if that works? (on your current stuck). If not then it may just be the car refusing to read that USB for 1 reason or another!
not tried my songs on her usb but to be frank, its a rather old USB. my dad has just given me an old memory stick of his so i think im going to transfer a few songs over and if it works, ill just use that. I have a feeling maybe the male part of the USB is damaged one way or another so proberbly not reading it right as you mentioned.
when you say you re-downloaded them?  where did you download them from?  If its a legit site then they may be DRM (Digital Rights Management) protected in which case they won't play other than the authorised device.  If thats not the case are they MP3 format?  can you try the stick on another car or another PC?
