Reverse Gear
Might be something of nothing but I recently purchased a 2013 Ford Fiesta 100ps ecoboost in blue, it had only 7,000 on the clock.
Now I'm not sure if it is just me getting used to the car or a potential problem,but getting it into reverse is temperamental.
Sometimes it goes first time, other times it makes that horrible squealing noise. Is it like this was a fault or something I just need to adjust to?
I think they all like that i used to put my in 4th then reverse and it akways went in better. Hope this helps
I have had a few Fiestas over the years and have always had difficulty selecting reverse gear, I should not worry about your problem, every morning when I have to reverse out of my garage I just have to make sure that it is engaged properly otherwise I get a grating sound.
As Above ^^
The 5 speed box on the fiesta is renowned for getting into reverse.
When I owned a Fiesta had the exact same problem to make sure just select 1st move very slightly forward (Just a nudge) then select reverse and it will easily shift in. Hated that about the fiesta.
Thanks everyone :) pleased to hear it isn't just mine, even though it's a shame it seems to be an on going problem
its on going because thats the way they are, theres no sychromesh on reverse so the b5/ib5 will allways be like that, there was a slight9 improvement in 2010 when a modified 5th gear synchro clutch slowed down the input shaft while engaging reverse.
it basicaly is a box designed 34yrs ago,
I used to find double clutching helped in my Fiesta.
Also make sure you are not moving forwards even a little bit when trying to engage reverse.
Non-synchro'd reverse is so annoying, I usually just crunch them in as I'm an impatient bugger! :laugh:
Fortunately the Focus is synchro'd but still doesn't like reverse from a standstill, I find lifting the clutch slightly while pulling the knob slips it in with minimal effort though.
Do we really need to know about your knob pulling? Lol
Ha, well I just thought it might help other people get it in easier. :wink:
