security/alarm
Does the ford ka titanium 2012 have an alarm?
Thatcham category 2 immobiliser
Does it matter though - Have you ever heard of a thief stealing a Ford Ka?
>;O)
Thanks, does it alarm as in make a noise though? If i try to open a locked door should an alarm sound? Thank you.
It's delayed from initial activation by about 120 seconds. To test leave frönt window open, lock door, wait 2 minutes, open door from inside via open window. Alarm should sound. Or sensors should pick up your hand movement.
Another way to test is to open the car with the physical key blade rather than remote and open the door.
If you don't put the key into the ignition within a short period then the alarm should sound.
To silence it you just put the key into the ignition and turn it to I.
Sent from my SM-G930F
A check on fordetis would tell you if it had an alarm or not!
Thanks for your advice guys, have followed your instructions but still no alarm going off. Will message ford etis. Thanks for the tip.
The alarm might not sound if the speaker cone is broken or disconnected but all of the the lights should flash hazard warning style!
