Headlining removal Mk6 ?
Can anyone please advise, the proceedure for removing the headlining in an 07 Style, in order to change
the roof mounted aerial sited above the front windscreen?  Will I have to remove it completely or only partially?
Thank you.
no need to remove headlining, just the interior light assy, then you have access to the aerial base, torx screwdriver to undo base from cable assy.
Brilliant.  Very many thanks Ian.
Rgds Pete.
