Wing mirror & electric window questions
Hello everyone, I've had my mk7 fiesta about a month now and it still needs a few little things done to it.  The first is both wing mirror caps are loose but it looks like it's the clips on the actual main part of the mirror that are broke not the mirror caps,  I have seen a pair of wing mirrors which I plan on buying and putting my caps on but I'm not sure if they're the right type.  Is there only 2 types of mirrors on a mk7 (2009 1.4 tdci style +) powerfold and non powerfold? I currently have non powerfold and don't want to upgrade just replace what I have already.
Also my drivers side window requires me to press the button 5 times to get the window to go up or down, it just goes down in stages rather than one motion, I have tried resetting it by holding the button etc but it has no effect.
Finally the rear drivers side window winder is missing, is this the same as previous years window winders or do I have to get one specifically for a mk7?
Cheers guys!
I changed the offside mirror on mine and swapped from a power fold to a non power fold as they are available very cheaply on eBay.   A tip though.   When you take the old mirror off, tie a piece of string to the electrical connector and pull it through.   It can the be used to pull the cable of the new mirror into place.   This saves a lot of time and effort.
Sorry, can't help with the other problems.
Thanks for the reply and tip Bobr! Any idea if there are only 2 kinds of mirrors available? Powerfold and non Powerfold?
I've never heard of any other kind.
