MK6 Upper Engine Mounts
I want to change the upper engine mounts on my fiesta as I think one or both is the cause of an issue I have. How easy are these to change?
Anyone? Is it a case of supporting the engine with a jack and then undoing and replace?
I haven't done it on a Fiesta, but it's usually pretty simple, just support the engine remove about 4 bolts per mount.  Think you'll need to remove the battery for access to the NS mount.
Thanks mate yeah I believe the battery is in the way for that one. I've changed them on an A4 just wanted to make sure the process was as simple as it was on that, however on the A4 the engine needed to be jacked up to get it off the mounts. I don't believe this is the case with the Fiesta though...
