ST150 Warning lights question
Hi, I am having funny times with my st150 recently I had engine light off maybe some of you no the cluster was loading later, went to ford they quoted me £600, came home changed radio fuse as I blown the fuse out when changing radio for aftermarket from then cluster works fine and engine light went off then 1 week ago I had circle light on with exclamnation mark in middle turn ignition off then on it turn off, this morning same happend with abs turn off ignition and on then its gonne what cld be problem ?!
I was reading somewhere the earth cable could be loose where can I find it
