New purchase questions
Hello
I have just purchased a 2010 Zetec KA as a first car for my daughter to learn to drive and as a second car for the house. I have some questions would someone be able to answer.
1. There is no spare wheel. Is this correct and I'd so would a full size fit?
2. Is Bluetooth standard on the Zetec as I couldn't see a "Tel" button
3. Looking through the grille it looks like it has 2 radiators one in front of the other, is this correct? And if so what's the one at the front.
Sorry to make my first post all questions.
Phil
I cant even remember if the Ka has a spare wheel well to be honest or if its underneath on a rack with a bolt to undo under the boot carpet. My Focus had no spare so i bought one off ebay and the bought the surrounding foam floor raisers from Ford. If there are two rads i would imagine one is the condenser for the air con?
Put you reg in on Registration Look Up on here and it will bring your Ka's factory build data up showing what spec it was built with.
https://www.etis.ford.com/vehicleRegSelector.do;jsessionid=3C4FD3F2C3F2AF102531F648D1743842.fcvas506
3 minutes ago, WES180 said:
I cant even remember if the Ka has a spare wheel well to be honest or if its underneath on a rack. My Focus had no spare so i bought one off ebay and the bought the surrounding foam floor raisers from Ford. If there are two rads i would imagine one is the condenser for the air con?
Thanks for the reply.
There isn't even a jack. Need to check if a full size wheel will fit before getting one.
I think your right about the Rad. It will need a replacement soon as the honeycomb is coming out. Its not leaking but needs sorting
If its coming apart then i doubt the air con will work as its filled with gas refrigerant. Depending on which one you have looked at that is, the rad or the condenser?
I had a look online and the wheel is underneath unless yours is missing then?
I doubt you will get one much cheaper -
Look at this on eBay http://www.ebay.co.uk/itm/192034488517
Hi
It has a spare wheel well in the boot, with a foam insert that carries the compress and some tools.
Just noticed the electric near side mirror doesn't wor. Can't hear the motor working is there a fuse I should check?
7 minutes ago, Phil-1 said:
Hi
That was like my Focus, i bought the wheel off ebay and then boot floor raisers from Ford. Check the tyre foam as it has a use by date on it.
Have you got your manual to check the fuse location as i dont know sorry? You can view it as a PDF online if youve not.
http://m.ford.co.uk/OwnerServices/Owners-Manual?selectedYear=2010&selectedModel=Ka+(2008)
