PCM update after replace Catalyst and Lambda?
Iantt, you are a GENIUS! SOLVED[emoji1] [emoji2] [emoji106] [emoji109] 8c1b604269f68d44c4fb20c8d5030e13.jpg
Verstuurd vanaf mijn HUAWEI NXT-L29 met Tapatalk
I know, I'm a genius!! Ha ha. Pitty I didn't see your original post until tonight or you would have solved it earlier. What you need to do is put another fuse in and clear the codes and try it, either of the sensors could have shorted out causing the fuse to blow so it may blow again. Let us know how you get on.
I do, i replace the fuse already and clear the codes with an ELM327 adapter from AliExpress and the Torque app.
Just need to drive it for a few days and see if it's ok.
