My ST170 'project'
Small update as light ended play, FINALLY!!!! Got one of the wishbones off, what a pain in the backside.  Used plenty of copper grease between the bolts so If I do have to take them off again, I won't use umpteen grinding discs and loose my temper.  Now the only thing is how shiny the wishbone looks.  So the rest of the underside will need to match now.  But for the time being I'm just focusing on fitting the suspension(mainly because of the weather) also I've seen some rust under the rear arches(surprise, surprise)while I was grinding away, so I've used the wire brush on the drill to get it to bare metal and put on some Hammerite rust converter
