LED Lighting Upgrade
@Daddy Nev are the Novsight bulbs still available on Amazon UK? I couldn't get the link you shared previously to work.
Look like they are out of stock or no longer available at Amazon UK. They are available on the US Amazon but not for import to UK. Ive found them here, and they are the same type and make.
https://www.ebay.co.uk/itm/153416534502
Great, thanks @Daddy Nev.
I'm right in thinking that these are a straight swap for the bulbs that are currently in the car? Nothing extra for me to do?
Gone will be the horrible orangey\yellow light for a nice sharp white DRL.
The bulb is a straight swap but the existing wiring will need an adapter as the LED pins are different to the Halogen wiring. You will need two H15 adapter leads to extend the cable and give you options on the led pins. I don't have any pics of the wiring from the plug to the adapter. Get a multimeter and just do a pin test and connect up and use some heat shrink to ensure the adapter pins are in the OEM connector nice and tight.
https://www.amazon.co.uk/Wiring-Connector-Canbus-H15-lh1540-assembly/dp/B077Z9KDBG/ref=sr_1_2?dchild=1&keywords=h15+cable&qid=1624725206&s=automotive&sr=1-2
When I replaced my H15 halogen for LED, they were straight swaps. No additional wiring of any type. What makes these H15s different from other H15s ?
No idea as the pin out should be the same for Halogen as LED. LED out of the box didn't work for me and I had to meter the wiring to ensure the correct polarity. I then added the extra H15 adapter leads to lengthen the cable and make easier connections to the LED. For the sake of a few quid, I'd recommend getting the adapter lead anyway as the main lighting cable is quite short and the OEM connector block is poor and pops off very easily.
All I can say its to try it and see. I had issues and maybe others won't. Negative ground is the pin closest to the fan.
DN
