Mk3 LED indicators
Has anyone done the LED front and rear indicators with external ballast/resistors?
Can I have a soundoff of which bulbs and resistor values you used and where you got them from please?
Ta muchly :biggrin:
Hello if you take a look at my reply to a post called focus tinted rear lights pictures you will see the bulbs I used and the ballast but it is for a mk2.5 rear lights hope it helps but the effect of the flash are good
thanks Darren, Looks like the 2.5 uses 21 watt filaments too so the LED/ballast combo should be the same =]
