High level brake light
Hi can you help?
High level bulb has blown what type of bulb is it as not listed on halfords or autobulbsdirect
Thanks in advance
Is this for a fiesta? As you profile says focus.
mk7/7.5 fiestas have LED centre brake lights so it's a replacement unit, £30-40 new from ford.
Do you have a picture of the bulb. I changed the bulb on my mk6.5 fiesta and it looks like the same fitting as the reverse light (955 fitting) which is the one which slots in. Don't know if it's different.
Yes it's for my sons fiesta mk6.5 I'll provide a photo but I must say it does look like the reversing light I swapped for leds on Friday
I'm pretty sure the brake light bulbs should be T10 (aka W5W or 501).
Reverse bulb as shown is a T15 (aka W16W or 921).
Hi clive
the bulb in the photo was taken out of the brake light and it looks the same as the reversing light I removed from the same fiesta. I will try and find the old bulb and see if it fits
it will fit , thats the right one.
Thanks mate
Thanks Ian
may consider the led bulb I used for his reversing light if it will fit
Thanks Ian
found the old reversing light removed when replacing with led and it works a treat.
