Ford focus 1.8tdci thermostat change
Morning all,
I am going to give my car a full service at the weekend including changing the anti freeze and thought that I might as well change the thermostat at the same time as it's done 93000 miles.
I was looking at the flange that you unscrew the 3 bolts to get to the thermostat am I correct thinking that if I take this off the only gasket I need is a new one that comes with the thermostat a round one, or is there one that sits in the flange
Thank you for your time
It’s just a rubber seal on the thermostat, nothing else to worry about.
Hi thanks for that also is there a drain plug at the bottom of the radiator to drain antifreeze out or which is the best way thank you
I always pull the bottom hose, I’ve seen the drain plugs on radiators snap or cause issues sealing again.
Ok cool thanks for help mate how does the flange seal back up then once you take it off
The round seal with the thermostat creates the seal.
