Mk2 Automatic won’t start even after battery change
Hi all
Got a 2006 Focus Station Wagon automatic. Been regularly serviced, has only 42000 miles on the clock.
Started off a few weeks ago, when turning the ignition, it huffed and puffed a few times, then started. Then, a few weeks ago during the snow, she just gave up and wouldn’t start. Engine turns over, but no ignition.
I changed the battery thinking it might be the issue, but still the same problem. Just won’t run.
Any ideas? I’m no expert with cars. Would just like to know what it could be.
Also, can anyone recommend a good Ford mechanic in South Manchester?
Thanks.
You could really do with being able to read/check for stored error codes, to do this you'd need a modified ELM327 cable, a Windows laptop and Forscan software.  (If you google the terms you'll find plenty of info).
Otherwise as you touched on you're looking at going to garage with is likely to start costing money pretty quickly.  You might get a recommendation on here for a good garage in your area if you wait long enough but seeing as your car is now a non-runner you can see for a decent garage here: https://www.goodgaragescheme.com/
Don't forget to post back with how you get on (it might help someone else in the future).
Drive selector interlock switch?
